06-30-2016
11:44
09:12
AlvaroFitbit
06-30-2016
11:44
09:12
AlvaroFitbit
After loving my new fitbit surge for 3 weeks it's suddenly stopped working. Yesterday I noticed the watch and the green light at the back had stopped, and thought the battery needed charging. When I tried to sync it the message said 'tracker not found'. I turned bluetooth off and tried to restart it but there is nothing. Any ideas please?
Best AnswerWelcome to the Community @K8tie! Is your Surge tracking all your activities correctly? Is it turned on now? If it's but it's not syncing, check out these syncing troubleshoots. Make sure that there isn't another bluetooth device that may be creating interference during the process. Setting up your tracker as a new device following @AlejandraFitbit's instructions may also help you to bring it back to sync as usual. Also, make sure that your mobile device is running the latest version of the Fitbit app for Android as per @MarreFitbit's post.
Hope this helps. Let me know the outcome.
