Hi All. Such a frustrating encounter with Fitbit online support today.
So, I got my first Surge in late March 2016. The strap split and came away from the face in May 2017 (the tracker was not subjected to anything unusual or harsh wear and tear) and at 14m of use, I don't think that damage like this was reasonable. Particularly for a device that is designed for training/running etc.
I received a second device under the warranty in the post. Great. Except now, a bubble has appeared on the strap just under the face. It's obvious to the eye and annoying. Not satisfactory or expected.
I called Fitbit and am told that I am 35 days out of warranty. The 'two year rule' in the UK/EU relates to the first purchase and not the second I am told. Madness. So the first Fitbit gets a 2 year warranty but the second one, less than a year. It makes no sense.
Anyway, I wonder what other people's thoughts and experience of this is. I think it's misleading to offer a 2 year warranty on a device but not when it's a replacement when the first was faulty.
Subject to what Fitbit say, I intend to rely on my statutory rights under the Consumer Rights Act 2015 and demand a replacement given that its of unsatisfactory quality and not fit for purpose. It's been subject to reasonable wear and should not have a bubble appearing on the strap. They offered me 25% off a new one. No thanks! Just sent me a device where the straps work and don't become defective!!
Any thoughts welcome.
On my 3rd one in four years. All three faulty straps and ended up super gluing them. First fit bit just froze up could not get it to reset, out of warranty, bought another one. That lasted less than a year when the red light would not go off, they sent me another one. This one failed after about 1 month with only able to get running app to work, nothing else works.
You can find a replacement SURGE band on Amazon/google search. I ordered one and it fit fine and for me the removal and installation was easy. Your mileage may vary :-).
I got mine from SoulenUSA/Amazon. $10 or less.
The problem is that while the touch screen still works, none of the buttons work. I have no idea if this is a result of sitting in my drawer for a year? or if the updated software turns off the buttons on old FITBITs so you have to buy new ones. NOT in my case.
Best AnswerI am on my fifth with faulty strap/band. I got two replacements from the shop, and Fitbit has sent me two out of the warranty. It is very clear that it is a manufacturing fault. Now however Fitbit will not replace my last one that got the same problems as those before. They just says it is out of warranty.
As someone commented, Fitbit knows very well that the watch will be broken in a short while. To regain respect they should put a lifetime guarantee on their watches. I will soon take a photo of the three broken ones I have at home, together with a broken Fitbit Scale I also have.
This is not low budget products, but they appear as very low budget stuff.
Best AnswerI have a similar problem and in the past Fitbit have replaced my Surge but this time they are only offering a small discount so I have decided to end my association with Fitbit - I have just sent this email to them and will raising a complaint on Resolver see resolver.co.uk
