It's great to have you here @BrijeshK! Currently, it's not possible to see just the total distance for bike. You can only check the whole distance that you've done with your tracker.
Hope this helps! ![]()
Is there any plan to add this feature? I know it's been talked about on these forums for a long time.
Welcome back @GeoffLake! I've found this suggestion today show distance or time which is almost the same that you're looking for. If you would like to be more specific and post another one, you can check our Feature Suggestion board, those are viewed by our engineers and the status will change based in Fitbit plan's.
Thanks for participate in the forums!
