02-16-2020 02:37
02-16-2020 02:37
Where do i get strap replacement for my fitbit surge in kuala lumpur?
Best Answer02-17-2020 22:18
02-17-2020 22:18
Welcome to the forums!
I'm sorry but there are no strap replacements.
Contact support to see what your options are. Use Help at the top of the forum
Wendy | CA | Moto G6 Android
Best Answer02-29-2020 09:50
02-29-2020 09:50
Amazon sells kits to replace the strap. Their are videos of the procedure on YouTube.
The two ends of the band are not interchangeable so I suggest changing one side at a time.
I've replaced the bands on two different Surge units with little problem.
While you are doing this, you might also want to change the battery. Also a soluble on Amazon.
