07-01-2016 09:21
07-01-2016 09:21
Best Answer07-01-2016 09:32
07-01-2016 09:32
Welcome to the forums @jazzland
You try restarting the Surge? It's like rebooting your computer.
Let us know.
Best Answer07-01-2016 09:37
07-01-2016 09:37
Best Answer07-01-2016 10:01
07-01-2016 10:01
@jazzland I had a similar thing happen the other month, but I was just one time zone away. It took a day or so before it got back to my usual time.
As long as it's the right time for you, it doesn't matter if it's Costa Rica or Chicago.
Keep on stepping!
Best Answer07-03-2016 22:29
07-03-2016 22:29
I have this problem whenever I travel. I have had luck changing timezone setting from auto to manual so you can choose the timezone you are in and then force it to sync. Good luck!
Best Answer08-02-2016 06:23 - edited 08-09-2016 04:49
Welcome to the Fitbit Community @jazzland, and thank you for sharing those suggestions @Emiliefair, @Odyssey13.
If you find this inconvenience again, make sure the time in your computer and phone are correct before updating it, and you can also try changing your timezone manually and select a random timezone, then force sync your tracker and change it to automatically again, you can do this a couple of times if the time is still not correct. I hope this helps in the future.
