02-03-2016 12:47
02-03-2016 12:47
I love my fitbit & its web site but am finding that not all foods are in the database
and can't find the nutition information need to add it as a custom food.
Any help would be appriciated,
Thank you- Ian
02-03-2016 12:51
02-03-2016 12:51
Hi, @ianmark55. A lot of people, myself included, track food using myfitnesspal. I think their database is about 10 times the size of Fitbit's and it integrates nicely with Fitbit. You can also add a custom food into Fitbit. If you can't find the nutritional information anywhere, a larger database might not help you, either. Almost all the databases seem to be searchable on the internet, you should be able to find it somewhere.
MakMak | Community Council
02-03-2016 12:51
02-03-2016 12:51
02-03-2016 12:51
02-03-2016 12:51
I use Myfitnesspal instead. A much better food database and you can link your fitbit account.
02-06-2016 00:07
02-06-2016 00:07
Thank You, Yes it is a great site!
04-06-2016 04:45
04-06-2016 04:45
05-25-2016 04:49
05-25-2016 04:49
05-25-2016 04:52
05-25-2016 04:52
05-25-2016 05:12
05-25-2016 05:12
You can log your food in my fitness pal and link your two accounts. Then you don't bother with the Fitbit food database at all. I used to have this set up and it worked fine.
I now prefer to keep the two separate because i have a set daily calorie target regardless of how much I exercise.
05-25-2016 23:29
05-25-2016 23:29
06-08-2016 11:01
06-08-2016 11:01
Hi....do you have to pay mfp to be able to log in food?...how do you link the app to my fitbit account?
so when I log in my food , do I always have to do it in directly to mfp instead of my fitbit app?
I appreciate your help
06-08-2016 11:23
06-08-2016 11:23
06-11-2016 15:42
06-11-2016 15:42
I agree Fitbit should integrate or buy a food database. I find it very frustrating trying to log food. I am tryng to be healthy and cook for myself but many times the default choices that come up on the food database are a bunch of restaruants that I have never even heard of. If they are not going to upgrade the database it would be nice if the first choices are just for the food typed in and not purchesed from a restaruant.
It also seems when adding food on the iPhone app and through the PC on the website is a different experience. On the iphone app it gives a slide bar with choices for calories. I may be doing somethign wrong but I find it very frustrating. I kind of use it just as a guideline but I would imagine that people that intesnsely track their data would find if very frustrating as well.
06-11-2016 15:57
06-11-2016 15:57
How do you link your fitbit to myfitnesspal? Does it still show up on the Fitbit Dashboard?
06-11-2016 20:57
06-11-2016 20:57
@Ruger9, once you sign up for mfp, either from the website or the app for mfp, you can add apps and devices. Just open that, select Fitbit, log in with your Fitbit credentials and it will start sharing. Exercise and food gets sent to Fitbit, steps and weight get sent to mfp. Food transfers as a meal summary rather than individual foods.
06-11-2016 21:25
06-11-2016 21:25
06-11-2016 21:37
06-11-2016 21:37
@c1224, you can track things however you want, you just need to be aware of what transfers which way, since one program or the other will not be accurate if you're not sending it the right information. In your way, all you will be doing with mfp is entering food, which means that Fitbit will give you more accurate overall results.
06-11-2016 22:02
06-11-2016 22:02
04-06-2017 21:19
04-06-2017 21:19
I agree with you! It is very convenient to just have a one stop shop rather then having to go to my fitness pal. Another thing that I don't like about it is that if u use Fitbit then it won't record in my fitness pal as well. However, it will record the other way around. Also it would be nice if they can show us that we are getting all the nutritional values that we are to get on a daily basis. Just like my fitness pal
