09-16-2017 11:46
09-16-2017 11:46
Had the Surge approx 2 months and set up then. Now can see it can do so much more, I want to go back to Square One.
How?
Best Answer09-16-2017 14:11 - edited 09-16-2017 14:13
Easy enough, go to blue tooth settings on your mobile and forget or delete your surge.
delete the fit bit app
go to gmail or yahoo and get another free address - sign into it so you can get mail
go to fitbit.com/setup and download the fitbit app and install as a "new user" using the email you just set up.
Look at you, you're a new guy!
Welcome back @JustMalcolm02 (or should I say JustMalcom03?)
WmChapman | TX
Ionic, Versa, Blaze, Surge, Charge 2, 3 SE, AltaHR, Flex2, Ace, Aria, iPhoneXR "Every fitbit counts"
Be sure to visit Fitbit help if more help is needed.
