09-09-2017 05:26
09-09-2017 05:26
Hi,my Surge 2 wristband broken.Someobe know hiw to fix or replace wristband?
09-12-2017 10:18
09-12-2017 10:18
I found replacement strap with tool,maybe I fix it.There are sore draw and found video on Youtube.
09-10-2017 12:36
09-10-2017 14:09
09-10-2017 14:09
Yes,I found it.But I noticed that sell fir Surge not Surge 2.It is the same strap?
09-10-2017 14:15
09-10-2017 14:15
It should be as I don't believe there was ever a surge 2 made. Does yours look the same as the original surge?
09-11-2017 01:41
09-11-2017 01:41
Looks the same.I found my order,and Im not sure now.On order I have Fitbit Super Watch Black Large.But looks the same.On my surge clasp is broken.I try fix it when I buy it on amazon.
09-12-2017 05:28
09-12-2017 05:37 - edited 09-12-2017 05:38
@jalfik wrote:Yes,I found it.But I noticed that sell fir Surge not Surge 2.It is the same strap?
I'm betting dollars to donuts there is no such a thing as a "Surge 2".
09-12-2017 10:15
09-12-2017 10:15
Yeah,probably I made mistake..But problem it us the same.It means rubber strap at clasp(one side).
09-12-2017 10:18
09-12-2017 10:18
09-13-2017 04:32
09-13-2017 04:32
I'm happy you found a solution to the problem, @jalfik.
09-13-2017 04:38
09-13-2017 04:38
Not yet,Im wating for parcel.But close.I let you know when I fix it:)
09-16-2017 12:28 - edited 09-16-2017 12:51
Hi @jalfik! Thanks for posting about the issue you're having with your Fitbit band!
Since those steps didn't solve the issue you're having with your Fitbit Surge band, I've requested to our Support team to create a case on your behalf. You should soon receive an email from Customer Support at the email you used to register with the Community forums.
Please keep me posted!
