01-01-2016
10:35
07:19
CindyFitbit
01-01-2016
10:35
07:19
CindyFitbit
How do you make the screen brighter ? My charge was so much brighter than this ! I can barely see this at all ? Can any one help? I tried he backlight. Doesn't help much
01-01-2016 16:27
01-01-2016 16:27
It's great to see that you've visited the Fitbit Community @Telliott01. Your Surge should bright enough for you to see it. Please try to restart your tracker. If this doesn't work, it could be a good idea getting in touch with Customer Support.
Catch you later.
05-25-2016 09:48
05-25-2016 09:48
05-26-2016 13:00
05-26-2016 13:00
Thanks for joining us @JoKerNyfb. If you haven't done it already, I would recommend following the instructions in my post above. This might help to get you back on track.
Keep up the super stepping.
05-27-2016 11:43
05-27-2016 11:43
Just got my surge and I have to say that I am very unhappy.
There screen brightness is trully ridiculous (and yes Edison I have switched it off and on). I would contact customer support, but seeing as everyone seems to have this problem and the general tonic is get used to it, I don´t think I am going to.
The menus are rustic to say the least and I can´t wait for all the other strap issues and condensation...
I usually research stuff before I buy and this time I didn´t, so I guess its my fault.
bob
07-03-2016 17:47
07-03-2016 17:47
The back light on the Surge is rediculous! I can barely read it. This thing is junk for $250. Combine this with the strap issues and condensation, give me a break. This is going back and I'll buy another brand with a better reputation. Who on earth ever thought the light on this was ok?????????
08-07-2016 07:07
08-07-2016 07:07
@SpanishBob Welcome to the Fitbit Community! So you switched the back light option on the Surge on screen settings, right? Or did you turned the Surge off and then back on? (You should try that as well). What about the restart process? Did you performed a restart? That should certainly help! (check @SunsetRunner's steps). @plintner1
Let me know how it goes!
08-07-2016 08:23
08-07-2016 08:23
@plintner1 wrote:Who on earth ever thought the light on this was ok?????????
i do
08-21-2016 20:32
08-21-2016 20:32
Looks like the screen brightness has been a known issue on the Surge for a while now, any chance that this can be updated in next release? It is very dark! can't even see it. Just compare with the Charge HR - there is no such thing as reboot and it will get fixed.
please can you provide a better answer so we know if this issue will be fixed or not?
Thx so much! greatly appreciated the effort in really looking into this issue
08-22-2016 13:02
08-22-2016 13:02
Mike | London, UK
Blaze, Surge, Charge 2, Charge, Flex 2 - iPad Air 2, Nokia Lumia 925 (Deceased), iPhone 6
08-22-2016 13:40
08-22-2016 13:40
08-23-2016 02:01
08-23-2016 02:01
Mike | London, UK
08-23-2016 10:08
08-23-2016 10:08
Thank you -- your funny!
Oh well, I'm getting use to it but I really can use a brighter screen... 😞
I cant see it very well when I work out (before or after) have to have light to see it, same at night...
Change is hard, but never impossible!
have a great day and thank you for taking the time to reply!
