Whenever I try it says no shortcuts, is there a way to set it up on my surge? I thought I did but I guess not. Help please. Thank you
You set them up from your dashboard. Go to your dashboard on the web and click on the gear in the upper right. Then click on the tracker. On the next page you should see a section that lets you set up your shortcuts. After you have finished, sync your tracker.
02-04-2017
08:47
08:31
02-04-2017
08:47
08:31
Hey, hey, @bmiller37!
Thanks for being here! I'm glad to see that your question was solved by our good and helpful friend, @SunsetRunner!
I would like to see you participating more in the Community, so I invite you to share with us on the Discussions section.
See you around!
Just setting up a new surge and on the exercise page it says NO SHORTCUTS. Have tried the solutions on the forums but it does not work. Any suggestions
