03-13-2017
13:12
09:17
YojanaFitbit
03-13-2017
13:12
09:17
YojanaFitbit
How do I specifically synch my surge to my computer. I placed the doggle in the computer and the watch near the computer/. What next must I do
Moderator edit: Clarified subject.
03-14-2017 09:16 - edited 03-14-2017 09:22
It's great to see that you've visited the Fitbit Community @Drsmile! Thanks a lot @MikeF, great to see you here! ![]()
You will find the steps on how to connect with your Fitbit Surge in the computer using Fitbit Connect, which connects via Wireless Dongle. If can also use a Window 10 computer with Fitbit Connect for PCs with no built-in Bluetooth.
Please note that if your Windows 10 has built-in Bluetooth you will have available the Fitbit App on the Windows Store. Once you've logged in into your Fitbit Account you will see the option to sync with a little "spinning wheel", after going to "Account" > "Surge".
Hope this helps! ![]()
Best Answer03-13-2017 14:09
03-13-2017 14:09
Installing the Fitbit app is the main thing to do. Where you find it depends on your computer type and age.
Mike | London, UK
Blaze, Surge, Charge 2, Charge, Flex 2 - iPad Air 2, Nokia Lumia 925 (Deceased), iPhone 6
