03-31-2017
19:08
11:02
YojanaFitbit
03-31-2017
19:08
11:02
YojanaFitbit
Since I race motocross it's important to stay in shape. I was wondering if anyone had any suggestions on which exercise catergory to pick? I was thinking work out; since I really only need it to tell me how long I rode, my pulse, and heart rate.
Moderator edit: Clarified subject.
Welcome to the forums!
Yes I would use workout mode. Its used when nothing else comes close.
Check out the discussions boards! A lot going on and I'm sure you have some contributions as well!
Wendy | CA | Moto G6 Android
Hi @MXRacer13! Glad to see you on board! ![]()
I think that @WendyB's suggestion is a good one! You can also check this thread in which they're discussing about the same topic: How should I register my activity? (Motocross). At this moment we don't have the specific option to track that activity since is not a base activity, but feel free to add your vote and comments in our Feature Suggestions board to ask for more option in the future: More activities.
As a piece of advise, you might consider editing your Workouts after you synchronize your Fitbit Surge with your Fitbit App. To have a better reading, you can name it as "Motorcycle"; it will make it a little bit more accurate in regards of your stats.
Hope this helps! ![]()
