05-29-2016 18:22
05-29-2016 18:22
06:25
07:20
05-30-2016
06:25
07:20
Let me give you a warm welcome to the Community! So let me see if I understood. So the led light on the screen is like changing from red to yellow? if so, this sounds indeed odd. Please post a picture of this issue, so I can investigate what is going on and try to solve it.
I'll be around!
Best Answer05-30-2016 15:20
05-30-2016 15:20
I haven't seen this problem mentioned in a while, if the 2 button reset* doesn't work, or turning it off through the settings menu, you'll need to contact.fitbit.com
*hold the left and lower right button down for 15 seconds, wait for the screen to turn off, could be another 40 seconds. Press a button to turn it on.
Best Answer05-30-2016 15:27
05-30-2016 15:27
Best Answer05-30-2016 15:31
05-30-2016 15:31
Did you send a request to fitbit support?
Cotact.fitbit.com
Best Answer05-30-2016 15:35
05-30-2016 15:35
