Lock buttons while excercising?
ANSWERED
I have a Surge and have had a problem with the pause or stop buttons being pressed while I exercise without me knowing(while lifting weights with gloves or lifting straps or while playing ball or hockey). It kinda sucks when I go to look at my stats when I am done and find the watch back in normal mode and only a portion of my workout was tracked. Is there anyway that there could be a way to lock the buttons out before starting to exercise? Maybe in a firmware upgrade at some point?
1 BEST ANSWER
Accepted Solutions
Thanks for stopping by @Jacklynjones077How you doing?
A way to lock your Surge while doing an activity is an excellent idea and I would like to encourage you to vote and place your comments in this request that was already suggested here: Lock buttons while in exercise mode, members of the Community can place new ideas in this board so they can be implemented in a future update, this is the best way to make your voice heard.
In the mean time I'd recommend you wear your Surge a little bit higher in your left wrist, so the button will be facing up. Trying to leave just the Surge on your wrist in a better position.
Hope this helps! Cat Happy
7 REPLIES 7
That's very annoying for me too, so I put a wristband over it and it helps keep me from hitting it.
It's quite far from optimal, but it seems to work and keep it from sliding on my wrist.
Welcome to the Fitbit family @Mick512 and @TomRL!  This is a good suggestion.  You can add your vote and submit your idea in our Feature Request board. I could find an idea similar to yours that you may find interesting. Rest assured that our team is working hard to provide you the best experience.
See you around!
Fitbit Community ModeratorVivian | Community Moderator, Fitbit
Did this help you? Help others by marking it as a solution! 🙂
Has nay progress been made on this issue. I've had my Surge for three days now. All three days I have lost my tracking due to this.
Welcome @Stunracing! Currently there is not a specific timeframe on when a feature like this will be implemented. Rest assured that our developers are constantly taking a look at your ideas to provide you the best experience with your Fitbit.
Thank you for your reply. The developers can take add long as they need as
I returned my Fitbit Charge in exchange for the Garmin HR. After losing 5
out of 6 workout sessions I was fed up.
Yes my surge does the same..but it vibrates when its been paused during the weight lifting .but i do get crabby cause ive got put the weights down during class to switch it back on....also i dont feel its reading my full heart rate cause i could be puffing and my heart rate is low but when im doing cardio it reads it fine ..just seems to be the wights or the workout part?
