01-30-2017 09:50
01-30-2017 09:50
Sometime this month the active minutes stopped being logged to groups. When will this be fixed.
01-31-2017 04:33
01-31-2017 04:33
It's great to see you in the Community @aliendancer! Thank you very much for this information. I checked and apparently this is a known issue and Fitbit is working on a solution. Sorry about the inconvenience that you're having with the active minutes in your group information. The bug affects some workouts and some others look just fine. I would suggest to contact Customer Support, so they can open a case for you to document all the details.
Please stay tuned to get more information about it, or to be informed about a possible fix or a workaround!
Thanks for understanding!
