06:44
11:15
11-28-2016
06:44
11:15
Welcome to the forums @Londonchick! I'll be glad to help you get back on track with your Surge.
It is not very common to see a battery drain problem on the Surge; here's @wmchapman explaining this and providing some tips on how to address it. Make sure to restart your Surge at least 3 times and then check on your battery's progress. If the problem persists after double checking the steps linked above; please let our Customer Support team know about this.
Now, checking on the syncing situation you've encountered; I've created a Syncing Masterpost that covers all platforms to help you get back on track.
If you see an error message; please attach a screenshot to your response and I'll be glad to look deeper into this. If you're unsure on how to do so, here's a post from @RobertoME that will come in handy. ![]()
Keep me posted on how this goes and let me know if you have any questions; happy holidays! ![]()
17:07
11:15
11-29-2016
17:07
11:15
@Londonchick thanks for the update. That definitely doesn't sound like normal behavior. In order to avoid this from happening in the future I suggest a restart:
Now, for deeper analysis I recommend contacting our Support Team. They definitely have the proper tools to take a deeper look into your tracker's behavior. When contacting our Support Team, please indicate the date and time this occur so it would be easier for them to identify any odd behavior. Good luck and keep us posted!
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
