01-29-2017
19:08
09:08
YojanaFitbit
01-29-2017
19:08
09:08
YojanaFitbit
Using gps hike function If I supply a battery recharge source while hiking how long will the memory hold? Looking to capture 30 hours
Moderator edit: Clarified subject.
01-29-2017 20:06
01-29-2017 20:06
@Iwowner, I moved this to the Surge Help Forum. It will get more responses here.
Best Answer01-30-2017 09:08
01-30-2017 09:08
Hope you’re enjoying the forums @Iwowner! Thank you @USAF-Larry for moving this post! In regards of your inquiry your Fitbit Surge can store 35 hours of GPS data before deleting some to make room for more. So, you were very close. To ensure that all your GPS data is saved to your exercise history, sync your Surge regularly. ![]()
A daily sync is recommended but not required for daily activities. Most Fitbit trackers record detailed minute-by-minute data for seven days, so if you're able to sync weekly you'll find all your data on your Fitbit dashboard. (Fitbit Alta records minute-by-minute data for five days; Fitbit Alta HR for six days). After seven days, Fitbit trackers can store daily totals for up to 30 days.
Hope this hepls! ![]()
01-30-2017 18:44
01-30-2017 18:44
02-01-2017 07:12
02-01-2017 07:12
Hello @Iwowner! Thanks for replying. Got it! Go ahead and test your Surge, and I encourage you to post back after you've tested it out, so we can have all the details of your workout conditions and feedback for other users! ![]()
Have you checked our Discussions board? If you're into Fitbit and fitness you may enjoy other users' comments. Check this board Looking for Fitbit Friends? Find some here! And have some fun interacting with other Fitbitters!
See you around! ![]()
