01-16-2017
09:06
04:20
YojanaFitbit
01-16-2017
09:06
04:20
YojanaFitbit
Hi Fitbit
the GPS symbol disappeared and not I can not track my golf games. It was working fine the whole time till this morning. I have shut down the surge to reset and removed the golf excercize and added it back and nothing is working.
Can you advise why?
Moderator edit: Clarified subject.
01-26-2017 13:18 - edited 01-26-2017 13:19
@MrRude @SOS79 @Ralph1061 @Stephen281 @Garfmahe828 @Buster_Bob @MHawk123 @Mikegillett
The following steps should help with getting the Golf exercise shortcut on your Surge to display on-device fitness stats:
1. Remove the Golf exercise from your Surge's shortcuts. Click here for instructions.
2. Sync your tracker.
3. Re-add Golf to your Surge.
4. Sync again.
Keep me posted if this helps!
01-17-2017 04:16
01-17-2017 04:16
It's great to see that you've visited the Fitbit Community @MrRude! Welcome to the Forums. Thanks for adding the picture, that's odd! Have you tried restarting your Surge a couple of times in row. I'd also would try to reconnect it as a replacement device. By going to your Fitbit App > Account > Set up a device. ![]()
Hopefully, it works as there isn't a reason why it is acting in this way. If not contact Customer Support so they can further assist you.
I'll be waiting for your reply! ![]()
Best Answer01-17-2017 18:34
01-17-2017 18:34
Yep, exact same thing has happened to mine!
I reset it, changed the excercise options, removing golf then re-sync, then add golf and re-sync. Nothing has fixed it. I will try the re register device, but I don't like the chances......hmmmmm
01-18-2017 08:25 - edited 01-18-2017 08:25
It's great to see you participating in our Community @SOS79! Thanks for the feedback. That's kind of strange, I haven't heard more case similar to this one, so if you try that and it doesn't work; it'd be best to contact Customer Support, so they can further investigate your case.
Please keep me posted, I'll be around! ![]()
Best Answer01-18-2017 12:33
01-18-2017 12:33
I've noticed the same thing today while trying to set up the surge before a round. Looks very much like it's been changed by Fitbit during an update as my friend who I was playing with had the same problem on his surge.
01-18-2017 16:40
01-18-2017 16:40
Ihave had the same experience and have sent a message to Customer Support, this appears to be a common problem which will require a 'fix'?
01-20-2017 05:05
01-20-2017 05:05
I also have the problem with the surge, as does my friend with the surge, clearly something fitbit have done.
01-20-2017 07:04
01-20-2017 07:04
I have the same problem. Bothe the GPS and Heartrate have gone from the Golf exercise. Something has been changed by Fitbit??
01-20-2017 08:53
01-20-2017 08:53
Same Problem here, used the GPS on the golf a lot in the last 6 months and the feature is one of the main reasons why I chose the Fitbit Surge. I contacted the Support team via chat and after a lengthy discussion and talking with 3 different support reps they eventually advised me that it is a known issue and the engineers are working on the problem. No other specific information was available...so no idea what the problem is or when they will fix it. I assume an update to the app removed the feature at some stage but I am guessing.
01-22-2017 03:36
01-22-2017 03:36
I experienced this problem yesterday. The last time I had used the excersize mode was two weeks ago. I had no problems.
I have restarted my Surge twice, removed the golf quick link, then re-added it. Still having the issue.
01-22-2017 17:54
01-22-2017 17:54
So I got with the Customer Service via Twitter and they are aware of the issue. They are working on the issue and told me that we ought to be able to still use the work out mode.
01-23-2017 06:45
01-23-2017 06:45
Hi, Work Out Mode, interesting response, there isnt GPS on the workout mode so it isnt going to track your distance. I guess we wait until they fix it.
01-25-2017 07:55
01-25-2017 07:55
Hello guys! Thanks for sharing your experiences and comments about this issue. We as a team really appreciate your feedback. I'm sorry for the inconvenience as @Mikegillett said, this is a recent bug that affects the Golf shortcut on Surge. Fitbit is aware of the issue and is working on a fix. In the meantime, I would suggest to use either "Workout" or "Walk" so you don't miss your steps during your golfing, this is a workaround until we receive the information on how to fix the bug.
I appreciate your understanding! ![]()
4. Sync again.
01-26-2017 15:19
01-26-2017 15:19
This worked for me. Thanks Derrick.
01-27-2017 21:48
01-27-2017 21:48
Unfortunately, golf activity has disappeared from selections and replaced with 'auto selections'.
me and the 60million other regular golfers would like it back please.
01-30-2017 06:10 - edited 01-30-2017 06:24
Hey there, @welmat! Welcome to the Family! Thanks for sharing your feedback. I would like to confirm with you, if you're getting back the option "Golf" after following the suggestions that @DerrickS posted above. If so, would you mind to clarify the "auto selections" information. I'll be more than glad to help you with this.
@Buster_Bob Thanks for the update! I'm glad to know that this worked for you. ![]()
Best Answer01-30-2017 10:18
01-30-2017 10:18
That fixed mine as well, but it is disconcerting that everyones Surge seems to have experienced the same issue in such a short timespan. Can you elaborate on the root cause?
01-30-2017 17:54
01-30-2017 17:54
Derrick,
I had tried this before and it had not worked. I decided to give it another try, and now the GPS symbol and the heart rate symbol are displayed. I won't be golfing for another week, so I will report back when I have given it a try.
Best Answer02-01-2017 07:25 - edited 02-01-2017 07:26
Welcome @volsung51! Thanks for popping by the forums @Mikegillett! Thanks a million for your feedback! These types of bugs are very unpredictable, I don't have too much information in regards of the root cause; but I know for sure that our Team is always trying to resolve any issue that you might have with Fitbit products.
That's why we are really thankful for your feedback and comments in every post, we have noticed that this is the best way to make your voice heard! I hope you keep coming to share how this worked for you. ![]()
Till next time and happy swinging! ![]()
