01-28-2017 03:17
01-28-2017 03:17
Two problems I cant turn off a walk exercise (gps)...not on screen , not on select button Surge is new since one day Will turn off when battery is ended
before that I was unable to start a non gps exercise
01-28-2017 06:25
01-28-2017 06:25
Does not sound like you are pushing the right button.
To stop it Push the lower right button. Then the top to totally end it and go back a screen
The Manual is very helpful and can make you understand what your unit is capable of
http://help.fitbit.com/resource/manual_surge_en_US
Wendy | CA | Moto G6 Android
01-28-2017 06:37
01-28-2017 06:37
01-28-2017 08:40
01-28-2017 08:40
I read the manual carefully. I tried to stop on the the lower right button. But no response whatsoever. I tried the upper right as well. The only way to end the exercise is to let it go on until the battery is out. If I then start the Surge I can use it as a clock and a recorder of data of steps, heartrate and so on but nothing else.
02-01-2017 07:54
02-01-2017 07:54
Hello sweetie @ingelapling! Thanks for popping by the forums! I think that @WendyB's suggestion is a really good option to try, but if you already did so and it is not working; must likely your Fitbit Surge is stuck. Why don't you restart your Surge a couple of times and try those steps after that.
Finally, as a last resort contact Customer Support, so they can further investigate.
Keep me posted! ![]()
