09-21-2016 04:42
09-21-2016 04:42
Best Answer09-21-2016 06:42
09-21-2016 06:42
I'm not sure there is a problem.
As well as tracking calories you burn through activity, your fitbit also tracks your BMR calories. These are the calories you burn just keeping your body alive (even when asleep). They are calculated from your profile settings (age, weight etc) so you needn't be wearing your fitbit to get them. What you are seeing for Saturday is the total BMR calories for the day. There's more information on this here:
http://help.fitbit.com/articles/en_US/Help_article/1381
Best Answer09-22-2016 05:36
09-22-2016 05:36
Best Answer09-22-2016 05:47
09-22-2016 05:47
That standard rate of calories per hour is what I would expect from BMR. Are you saying that the days you don't wear it get more calories burned than the days you do? If that's the case then I am at a loss to explain it.
Best Answer09-22-2016 06:33
09-22-2016 06:33
Best Answer09-23-2016 06:47
09-23-2016 06:47
Do you have a Food Plan set @FitM? What my friend @SteveH explains is very accurate, but this will also depends if you have a food plan and log your food.
I'd recommend checking these post to clarify this a bit better:
Hopefully this helps! ![]()
