Welcome to the Fitbit Community @Chrisjbooth
! At least two dozen GPS satellites are constantly in orbit around the Earth and broadcasting data. All GPS devices, whether your phone or a Fitbit Surge, require a direct path to these satellites in order to receive their radio transmissions. If the signal is being blocked—either because you're underground, near many tall buildings, or as a result of atmospheric effects—GPS will not work. Thus, whereas GPS gives you a more accurate measure of distance than step counting alone, the actual accuracy depends on both your environment and the weather.
If you're running with your Surge and the GPS signal is lost, rest assured Surge will continually search for a GPS signal as long as the exercise is in progress.
Your Fitbit activities will appear on Strava, and your runs and rides tracked by Strava will contribute to your Fitbit all-day stats. If you're interested in exporting your GPS data from your Fitbit Surge to Strava, see Can I export my fitness data to my computer?
Keep in mind that the following types of activities won't sync to Strava:
Hope this helps!
@Chrisjbooth wrote:
Get voting! It can't be that difficult as the code is already written into the blaze.
that's not a problem of code.
can be a problem of memory.
think about these devices don't have the same amount of memory as your smartphone or your computer.
in some cases, to add a functionnality, you must remove another.
