02-23-2016 16:37
02-23-2016 16:37
Best Answer02-24-2016 08:46
02-24-2016 08:46
It's great to see you on the forums @alid92! I see that @Dominique has provided valuable information in this thread. Also, I'd like to direct you to @SebringDon's epic post to explain Fitbit's Food plan, step by step.
Hope this helps! Let me know if you have any questions ![]()
10:11
09:23
02-24-2016
10:11
09:23
Fitbit determines your BMR with the Mifflin-St. Jeor formula (or something close enough). You can check it with this online calculator. Assuming you are 20, your BMR (as a 5’3/101 female) would be 1197. The highest activity level in the calculator (Extreme / Very hard exercise 6-7 days a week) would put your daily expenditure at 2275. That’s a lot lower than the 5000 you say your Surge reports.
What number did you get for calories burned on Feb-19, your lowest activity day during the past 30 days ("only" 17,800 steps)?
Dominique | Finland
Best Answer02-24-2016 10:24
02-24-2016 10:24
Best Answer04-11-2016 15:35
04-11-2016 15:35
Hey @alid92, thanks for the update! I'd like to know if this you're still having this issue as @Dominique's this is related with your personal information. I'd like to recommend checking your info on your Account Settings. If you're happy with it and the issue persists, feel free to contact Support, they'll be happy to give a hand on this.
Keep me posted!
