02-24-2016 07:41
02-24-2016 07:41
I am 64 and have a RHR of 56. It seems to be hard to hit areobic totals . For me it not hit until 127,and anerobic at 150. For me even running does not get there???
Best Answer02-24-2016 08:32
02-24-2016 08:32
Hi! I'm 60 and my numbers are very similar to yours. It's been a long time since I have been able to consistantly hit aerobic/anerobic while running. One place its possible is when I run a long uphille trail but not on flat. I am able to hit both by doing HIIT on an eliptical maching a 2 times a week if you have access to that. Just keep in mind that you are out getting some good exercise in any case! good luck.
Best Answer02-24-2016 10:11
02-24-2016 10:11
Best Answer04-11-2016 15:27
04-11-2016 15:27
Welcome to the Community @indydiva and @djjstew! I'll be happy to help you with this. To resolve the issue with your Heart Rate readings, I recommend wearing your Surge a bit higher than usual. 2-3 finger between your Surge and your wristbone.
It seem that you also want to set a food plan. This is really easy, yes it will give a caloric deficit. That means you can consume determined amoutn of calories. Let suppouse you are allowed to eat 1,000 calories, however you can increase that amount of calories with your activities. That's why you constantly need to sync your tracker to keep this information updated.
Hope this helps.
