Welcome to the Forums @sphynx and @Roxanne76! When the time on your tracker is incorrect, it usually means that it hasn't been syncing correctly. The first i'd like to recommend is that you restart your tracker. I noticed that you wrote from an Android device so try to manually sync it by doing the following:
Keep me posted!
