07-08-2017
06:28
11:13
YojanaFitbit
07-08-2017
06:28
11:13
YojanaFitbit
I have the surge which I use for tracking my running however I would like a more elegant tracker for when im
in the office. If I bought a fit bit Alta hr just for general day to day does it all feed into the one profile in my app ?? Thanks for your help
07-08-2017 06:43
07-08-2017 06:43
@Chesterchops Once you add it to your account all its accumulated data will go your Dashboard after it syncs.
07-08-2017 06:55
07-08-2017 06:55
Thanks very much ... now just need to decide on size
07-15-2017 11:12 - edited 07-15-2017 11:16
It's great to have you here my good friend @VF31AE3! Thanks for taking a break from stepping @Chesterchops. Welcome, welcome! ![]()
I love the Fitbit Alta HR design too, you have some many options to choose regarding band color; including the metal bracelet. You can pick the correct size using the print guide on the website. I encourage you to check more details about how to use two trackers in one Fitbit Account so you can have an idea on how it works.
Happy stepping! ![]()
