Welcome to the Community @ATwatches! Yes you can have more than one device paired to your Android device, it is like set up a new tracker
. Please take a look at this article that will provide you the information you need. Thank you @marcelov for your help.
To add you new tracker please:
1. On your Android phone go to your Fitbit account
2 Tap on the 3 lines on the upper left corner of your screen.
3. Tap on devices
4. Tap on the + sign on the upper right corner.
5. Choose the device you want to add and follow the instructions.
You can have more than 2 trackers on your account, however, it is possible to add just one Surge, or Charge HR. If you have a Surge and you want to set up another Surge, the app automatically will replace the tracker you already have. So if you already have a Surge, you can use any other tracker.
Let me know how it goes!
