Hello @Nathanjanmo welcome aboard to our Community. I've noticed that you have received good assistance from @Rich_Laue, however I see there is no other solution. I wonder if the issue still persist?
If still persist, I would like to review the steps with you to setup the music control to cover the basic:
Now, If you were previously able to control music but now see "Not connected" or "Connecting..." on your Surge, test whether you're able to control music after trying each of these troubleshooting tips:
Keep me updated how is it so far, I'll be around.
Best AnswerThanks, but once again, same directions I've tried several times. Basically, after I press surge classic on phone, it never has provided a pairing code whereas the surge always provides one. The pairing process on phone simply times out
Hi @kst8er86, it's nice to see you here! ![]()
Sorry to know that you haven't connect the Music Control feature. Which model of phone are you using? Please make sure that your phone is syncing and adding all your stats to your Fitbit App. Then try to restart your Surge a couple of times and follow @RobertoME's steps one more time.
Let me know if you encounter any error on the way. Once you are setup, click here for instructions on how to control music with your Surge.
Keep me posted if this helps! ![]()
Thanks for getting back @kst8er86! ![]()
I appreciate the time you're taking in working on this. Please make sure that your Surge Settings is showing the Bluetooth Classic in "Pair" and reboot your Bluetooth on your phone. Check that on your phone, Bluetooth is showing as "Surge (Classic)" under Available devices, and tap on that. As soon as you get the code on the Surge press the Action button (lower right) to confirm the pairing.
Let me know how it goes? ![]()
How you doing my friend @kst8er86? Nice to see you here again! ![]()
Thanks for sharing your feedback, it's of great help. Sorry about the issues you're having to use the Music Control. We strive for excellent customer service, and customer satisfaction remains our number one goal; I've sent you a PM, please keep an eye in your inbox!
Let me know if you have questions about it! ![]()
