04-03-2017 12:23 - edited 04-03-2017 12:24
I have read other's notes about just tapping on the run screen and the others show up, but when I tap on the run screen, it just shows me the 3 other run options (treadmill, lap, and free). My old surge had options under exercise with spinning, workout, weights, etc.
How do I load those back in?
My fitbit says "set on mobile or web"
04-03-2017 19:10
04-03-2017 19:10
Hi @Cheno,
Go into the settings for the tracker in the app, and select Exercise Shortcuts. There you'll find a list of the available shorcuts. Check the ones you want displayed. There are additional shortcuts, but you can only have 7 active at a time, so if there's one you want to add you may need to delete one you're not using first. Hope that helps.
04-03-2017 19:10
04-03-2017 19:10
Hi @Cheno,
04-04-2017 11:10
04-04-2017 11:10
Hi @Cheno! Please receive a warm welcome to the Fitbit Family! It's great to see you participating in our Community!
Thanks for making @WavyDavey's answer your Accepted Solution! Please take a moment to visit our Discussions board where you will find other members sharing their experiences and tips. This is a really good way to stay motivated towards your goals. In case that you haven't do so, check it out! You might be interested in these topics: Marathon Training or How do you break out of your sedentary lifestyle?
See you around!
07-25-2017 04:05
07-25-2017 04:05
I can see the exercise shortcuts on the app clearly listed but the watch doesn't show them, it displays "no shortcuts, set on mobile or web" even though they are synced. any thoughts?
07-26-2017 13:06 - edited 07-28-2017 05:58
We are very pleased that you have joined our Family here in the Forums @cranberry31!
Why don't you try selecting the types of exercise that your Surge will support from the list on the Surge Settings page of the website. Then sync those to your Surge and then the options should be available for use on the device.
Hope this helps!
