01-19-2018 06:51 - edited 01-19-2018 06:53
Hey guys, how are u? Today my Surge unloaded the battery, 0% and turn off.
When I try to charge, connecting the cable, the screen turns on but not continue to charge. Fifth minutes before I plug the cable into the energy and..... look for the screen (like as the attached pic). Locked up!!!
Can help me?
Look the photo:
Fifth minutes and nothing, locked up
01-20-2018 05:28
01-20-2018 05:28
Hi, @lucas_BRAZIL, try a restart. Do it at least 3 times, If that doesn't work, you might want to get in touch with Fitbit Customer Support on contact.fitbit.com and they can discuss your options with you.
01-20-2018 11:05 - edited 01-20-2018 11:42
Hi @lucas_BRAZIL! Thanks for stopping by! It's great to see you participating in our Community @Julia_G! ![]()
I agree with @Julia_G, try to restart your Surge if you haven't do so. And please try to reconnect your Surge to your Fitbit Account by following these steps.
How are you changing your Surge? In case that your Surge is having issues charging, we recommend plugging your charging cable into a USB port on your computer or other low-energy device. If necessary, you can use a UL-certified USB wall charger. Don't use a USB hub or battery pack to charge, and only use the charging cable that came with your tracker.
Also try to clean the contacts of your tracker regularly. These contacts can become obstructed by microscopic dirt or debris that prevents them from making a good connection to the charger. Use a toothpick or toothbrush to clean the charging contacts; do not scrape them with anything metal because this may damage the plating and result in corrosion.
Hope this helps! ![]()
