05-27-2016 02:43
05-27-2016 02:43
I've just changed my phone from a Samsung Galaxy 5 to the 7 and since then I have not received any phone or text notifications. They are paired and I have tried unpairing and re-pairing, restarting my Surge but nothing. I can control music from my Surge though. Any answers please?
05-27-2016 06:43
05-27-2016 06:43
Actually I've got it working now, it was simply that I didn't have it set correctly in settings.
All good now, thanks
05-27-2016 04:04
05-27-2016 04:04
I have just done a quick check, and it does not appear that the Samsung Galaxy S7 is on the supported list. However, more phones are added all the time, so it will probably be supported soon.
05-27-2016 06:43
05-27-2016 06:43
05-27-2016 12:07
05-27-2016 12:07
So glad you got it working! And thanks for confirming that it works on your phone -- since it is not on the official supported list, it might really help someone else looking for this information.
09-16-2016 12:17
09-16-2016 12:17
what settings did you change to make it work on the galaxy 7
10-10-2016 22:41
10-10-2016 22:41
How did you change this? In the dashboard on the phone? The settings on the Surge? Help please!
11-06-2016 13:04
11-06-2016 13:04
Hello,
where in settings did you correct error?
12-03-2016 07:26
12-03-2016 07:26
01-10-2017 07:08
01-10-2017 07:08
I just recently changed from a Galaxy S3 to a Note 5. I am also not receiving phone or text notifications. do you have to change settings in the phone or on the Surge?
01-11-2017 03:40
01-11-2017 03:40
@beachman Thanks for joining us in this thread and the Community! Please try turning off the call/text notifications, log out of the app, turn off your Note 5 and turn it back on. Once this has been done, open the app, log in and turn on the notifications, and sync your Surge. Finally, check out if your Surge gets the notifications from your phone.
Keep me posted on the outcome my friend!
01-11-2017 15:46
01-11-2017 15:46
01-12-2017 07:53
01-12-2017 07:53
A warm welcome to the Fitbit Community @beachman! I'll be glad to help on this. I would suggest trying this steps, I included some details that you have to check in your Android phone. Is your Fitbit Surge currently syncing? Are you receiving call notifications?
Keep me posted, I'll be around in case you need more help!
01-12-2017 10:25
01-12-2017 10:25
01-13-2017 14:32
01-13-2017 14:32
Hi, Sorry to jump in but I am also having trouble receiving sms/call notifications from my galaxy 6 (i think) to my alta. I've tried following the steps from various suggestions. Just tested it again now and still not working. What am I missing? Hope you can help
03-30-2017 15:38
03-30-2017 15:38
Getting frustrated, have tried several different things and my Surge will still not notify me of text/phone calls and still can't figure out how to control music. PLEASE HELP!!
03-31-2017 10:18
03-31-2017 10:18
HI @beachman, @ThePirate and @totallyforgiven! Welcome to the thread, thanks a million for posting your question!
@ThePirate and @totallyforgiven Please try the steps to troubleshoot your notifications. I've check the list of compatible device and noticed that Samsung Galaxy 6 is not listed, which meant that we're still testing the model and we can not assure it will connect flawless. You can give it a try to see if the steps helps. What model of phone are you using to sync @totallyforgiven?
@beachman I've sent you a PM, please take a moment to check your Private Messages!
I'll be around, keep me posted!
05-16-2017 17:31
05-16-2017 17:31
I receive phone notifications but not text on my new Surge. I call help line twice but issue was not resolved. I have an iphone6
05-17-2017 11:59
05-17-2017 11:59
We are very excited to have you as a part of our members @Newbrunswicker!
Congratulations on your new Surge! Please check these troubleshooting steps to connect text and call notifications on your Fitbit! Also make sure that your iPhone Settings has Notifications turn "On".
Hope this helps!
09-19-2019 04:26
09-19-2019 04:26
I’ve tried everything. Walk me through the steps please
09-19-2019 10:37
09-19-2019 10:37
Hi, @Ganoe, in order for someone to walk you through, you will need to let us know what phone you are using.
It might also help to know which Fitbit you have.
