I'm glad to see you here in the Forums @Friskeebusines, it's great to know that you're using your Fitbit as a helper to build some muscles! ![]()
What you described sounds odd! When you finished your workout, did you noticed if your Surge gave you the 1.5 hour in the summary of the exercise? If so, I'd suggest to restart it in case that it might be having internal issues.
I'd also recommend to wear your Surge a little bit loose when you have it higher in your left wrist, so the button will be facing up; that's in case that you might pausing it during your workouts since the buttons might be facing your wrist when you're moving your arms to lift the weight.
Give it a try and let me know if this happens again.
Hope this helps! ![]()
