01-07-2016 22:14
01-07-2016 22:14
Hi,
I've recently bought Surge, and Registered myself with my PC, and sync the device with the help of dongle provided with it using PC. Sync part works fine in PC.
I own an android mobile, and I've given login credentials in the app, it works fine. I've paried the surge with the mobile and it don't sync.
Does anyone faced the same issue and How did you solved it ?
01-07-2016 22:45
01-07-2016 22:45
Delete it from your list of BT devices in phone settings and then try. Don't pair manually, let the app sort it out.
