04-22-2016 19:46
04-22-2016 19:46
Ever since the Android upgrade to 5.1.1 my Galaxy S5 cannot sync with the Android App. I have restarted the Surge, updated the Fitbit App, and tried pairing again. Android sees the Surge under "Available devices". When I select the Surge, I get a popup that says "Pairing rejected by Surge". I tried Bluetooth Classic under Surge settings, but no dice. I can however sync the Surge with my Windows desktop over bluetooth.
Anyone else running into this issue?
Best Answer04-23-2016 08:02 - edited 12-06-2016 05:15
I'ts great to see that you've visited the Fitbit Community @BananaNutMuffin!
Let me help you with this, try doing the restart 2 or 3 times in a row this will refresh the internal logs of your tracker, your tracker should be working properly after doing it. To do so:
Let me know how it goes!
Best Answer12-03-2016 21:04
12-03-2016 21:04
This did not work for me. Any other recommendations?
Best Answer12-06-2016 05:22
12-06-2016 05:22
Welcome to the Fitbit Community @Bea_Bea! It's a shame to hear that you're experiencing this inconvenience. If you have already tried the steps that I shared in my previous post and the issue persists, I recommend contacting the Support Team and let them know the steps you've tried so far,they'll be more than glad to assist you.
Keep me posted!
Best Answer08-24-2017 07:22
08-24-2017 07:22
Has Fitbit fixed this Problem? My Surge is not seen by my Android after performing the recommended steps..... ARGH!
