11-06-2018
07:39
04:50
YojanaFitbit
11-06-2018
07:39
04:50
YojanaFitbit
I've managed to connect my pixel 3 to my surge but I'm not receiving text/call alerts. Any ideas?
Moderator edit: Updated subject for clarity.
11-07-2018 04:49
11-07-2018 04:49
Hope you're having a great day @ESharp! Welcome to the Forums.
Thanks for the steps you have tried to connect your Surge, good job. I was checking comparability for Google Pixel phones, but I noticed that this model is not listed on the official list of tested devices that connects with Fitbit products. That means that you have the option download the Fitbit App, but Fitbit can not assure that all the features will work flawless because the device is not totally compatible.
You can try to troubleshoot it to see if this help. In my experience I have a phone that is not in the list either, and I receive call and text notifications. Once in a while a need to troubleshoot my phone to keep receiving the text notifications but at the end it works.
First:
1. Turn off Bluetooth.
2. Force quit the Fitbit app.
3. Turn on Bluetooth.
4. Open the Fitbit app, which will initiate a sync with your tracker. After syncing, you should receive notifications.
If these steps didn’t work, try restarting your tracker and then turning notifications off and back on:
1. Restart your tracker.
2. Turn off notifications: In the Fitbit app under Account (upper right corner), tap Notifications. Tap the three dots in the top right and choose Disable Notifications.
3. Reboot your mobile device.
4. In the Fitbit app under Account (upper right corner), tap Notifications > turn on the notifications you want to receive.
If you're still not receiving notifications, set up notifications again:
1. Disconnect ("unpair") your tracker in your mobile device's Bluetooth settings. The instructions differ by device, but in most cases: Tap Settings > Bluetooth and find your tracker in the list of paired devices.
2. Open the Fitbit app under Account (upper right corner), Tap Forget or Forget Device to unpair your tracker.
In case of having an Android phone, also check your phone Permissions and leave location on to keep syncing with your phone, for more info check those suggestions from @ErickFitbit.
Hope this help!
03-29-2019 06:13
03-29-2019 06:13
I tried all of these things. it appears to work in that i can receive the test notification from the fitbit app on my pixel3 to the blaze but then that's it. all communication stops.
09-04-2019 13:02
09-04-2019 13:02
I just had a chat with support and was told that to this date the pixel3 is not on the list of compatible devices for any fitbit device! This is very troubling. i've had my blaze for many years and was thinking about getting a versa2 pre-order but now i'm not spending any $$ with fitbit until i know my pixel3 is compatible.
09-04-2019 23:05
09-04-2019 23:05
09-07-2019 10:31
09-07-2019 10:31
How do you reset the Fitbit back to factory settings? Just remove it from your account?
09-08-2019 03:19
09-08-2019 03:19
09-08-2019 15:12
09-08-2019 15:12
09-08-2019 23:26
09-08-2019 23:26
09-15-2019 23:15
09-15-2019 23:15
Have you had any luck with this yet? I'm going back and forth with tech support but keep getting the "we're working on it" responses. Weird thing is, mine was actually working for a while until it stopped. And it's just the texts that don't work, email and phone are good. Anyways, I took a shot and ordered the Versa 2, I'll let you know how that goes.
09-16-2019 07:43 - edited 09-16-2019 07:45
No. I have had no luck. My blaze is a little older. I had gotten one for my
husband about 2 years ago and his is working better with his pixel 3 than
mine. Lately he has had issues with the sleep stats not syncing! I'm really
so disappointed in fitbit. These phones have been around for about a year
now. You would think there would be some sense of urgency to get it right.
I find Fitbit to be the best tracker as far as data collected and the break
down of hate to leave the Fitbit community. For all these years it's just worked with my Galaxy phones. I had no idea support was so unhelpful.
09-16-2019 07:51
09-16-2019 07:51
As of 9/12/19 The pixel 3 is now in the list of compatible devices but it is not working for me yet! It's an update that according to Fitbit it IS supposed to work now.
09-17-2019 07:39
09-17-2019 07:39
I have had the exact same experience! Mine used to work for everything, then only showed the name of text senders and callers, and now only calls work. Fitbit support told me they were working on it. That is as far as I have gotten. No luck yet. I have tried resetting my device, reconnecting to my phone, restarting my phone, among other things.
09-29-2019 15:58
09-29-2019 15:58
Tried to setup notifications today, primarily for text messages, but was unable to receive notifications for anything from my Pixel 3XL on my Blaze.
Followed the various troubleshooting steps in various threads and was not able to find anything that worked.
At times, I really feel that most apps, including the fitbit app, are designed for iPhone with Android devices being an after thought. Not to mention the support for Android devices when the app doesn't work.
10-26-2019 10:33
10-26-2019 10:33
Broke down and bought the Versa 2 and everything seems to be working great connected to my Pixel 3. Haven't tried the Blaze in a while, was hoping to sell it for a couple bucks. Is everyone still having the same problems?
10-29-2019 12:36
10-29-2019 12:36
I am still having the same problem but good to know the versa2 works. I have not upgraded to Android 10 on my pixel 3 yet have you? Coincidentally I just caved and got the versa 2 as well. Just waiting for delivery.
11-11-2019 08:39
11-11-2019 08:39
I'm on a versa 2 and pixel 3. No notifications.
11-11-2019 19:23
11-11-2019 19:23
I just got a versa 2 and I also have a pixel 3 and my text notifications are working. The wet not working with my much older blaze with my pixel 3
11-12-2019 04:17
11-12-2019 04:17
11-13-2019 20:55
11-13-2019 20:55
What version of Android OS RU running?
