02-08-2016 10:39
02-08-2016 10:39
Hello
I'm using bike option with my Surge.
My Android is attached to the bike stem, so I'm able to view it on real time.
Is there any way to see some details in the app / dashboard?
Something like heartbeat, distance, route... etc.
Thanks a lot
Nitzan
Best Answer02-08-2016 14:05
02-08-2016 14:05
Yes you should be able to sync and see real time data on the dashboard. I use it for real time heart rate. But it's pretty unreliable. Some days works fine. Others just won't work.
Best Answer02-09-2016 07:34
02-09-2016 07:34
ok, thanks a lot, I'll see how I try it.
Thanks
