01-08-2017 06:56
01-08-2017 06:56
I would like to program my Surge for a run/walk interval time, but can't figure it out. I.e. Run for 4 mins, Surge will vibrate, walk for 30 sec, Surge will vibrate, run for 4 min, and so on....Looking for assistance on how to set up interval timer like this. Thank you!
01-08-2017 11:36
01-08-2017 16:14
01-22-2017 10:25
01-22-2017 10:25
Awesome help @SunsetRunner! Nice to see you here @GershonSurge and @Bosnhanson! As @SunsetRunner mentioned in his post above, check the page 20 of the product manual to check how to Track Your Splits During a Run.
I hope to see you around more often! 😉
Best Answer08-27-2017 20:00 - edited 08-27-2017 20:01
Programming SPLITS is not the same as INTERVALS. A split will tell you every X number of minutes or X number of miles how you are doing. An interval timer usually is set-up with TWO or more times/distances that don't give you information on how you are doing at that SPLIT, but a signal/vibration/buzz to CHANGE what you are doing. For instance, an INTERVAL RUNNER may want to run for 2 minutes feel a buzz and switch to walking to 30 seconds, feel a buzz and move back to 2 minutes...etc. They aren't looking for "what's my pace at this split?" A good example of an app that does both is Runkeeper which gives folks the option to hear audio cues about how they are doing at a distance and pace AND also allows to set interval cues. I wish people would stop telling folks that fitbit devices can SIGNAL INTERVALS when they don't. People waste a lot of money on fitbit devices that don't have an INTERVAL SIGNAL function. Right now I think only the Charge 2 actually allows programming intervals.
Best Answer09-20-2017 08:29
09-20-2017 08:29
Oh no! I had a charge 2 and had intervals programmed. I lost it and just bought the surge assuming it would let me program intervals and it won't?? Crap!!!!
Best Answer10-01-2017 02:52
10-01-2017 02:52
It's a shame that interval based programs cannot be done on surge.
Any roadmap for this to happen ?
10-01-2017 05:00
10-01-2017 05:00
Best Answer10-01-2017 07:23 - edited 10-01-2017 07:23
@JayWad wrote:It's a shame that interval based programs cannot be done on surge.
Never
the surge is dead, replaced by ionic
