05-31-2016 21:25
05-31-2016 21:25
I want to use (put on) my surge when running only.
- when i have the switch off, do i need to go to settings and switch off each time? (because when i do not i am seeing the heart rate monitor stays on)
- does it work in this way if i want to use it? which means the steps will not be counted ....
Best Answer06-01-2016 06:12
06-01-2016 06:12
The heart rate monitor is always on unless A) you turn it off via the device configuration, or B) you take the tracker off and leave it on a stable surface.
