Hi,
I'm a happy fitbit surge user 😄
However I usually have to set 2 or 3 alarms to wake me up. This makes me unable to use fitbit as my main alarm.
The reason, I believe so, it's because it vibrates during a short time (seconds ??) and then it goes off (auto snooze for 10m or so). Wouldnt be awesome if the alarm once triggered, would vibrate until you press snooze or OFF ? Like the scheme that we usually have in a phone i.e.
Glad to hear some feedback from Fitbit Team regarding this as a possible, or not, future feature in updates 🙂
Thanks
Great to see you around @rahman. I think this is a great which you can share on our Ideas Board, actually I already checked and noticed that there's a Suggestion about this. You can check put your commend that click "Like".
Keep the stepping up! ![]()
