01-25-2017 13:57
01-25-2017 13:57
In normal mode my surge basically tells me what time I went to bed and when I got up which I kind of know anyway. Since I switched to sensitive mode it has been reporting that I get about 4.5 hours of sleep each night and the other 4 hours are 'restless'. I'm pretty sure that I am getting more than 4.5 hours of sleep. I'm not sure if this is the 'normal' sort of data to expect.
I've tried reseting the surge but it has made no difference.
01-26-2017 04:55
01-26-2017 04:55
What a great day to step into the community @Linzbfc! Welcome. Using Fitbit to check your sleep is of great help to better understand your sleep patterns and quality, that's an awesome feature. ![]()
I'd suggest using it in the normal mode, to track your sleep. When your Fitbit is in "sensitive" mode your tracker records nearly all movements as time spent restless or awake. This setting is usually use for users who wake up feeling tired even though their sleep history shows sufficient rest. ![]()
The normal setting counts significant movements as being awake (such as rolling over) and is appropriate for most users. You can give it a try to see if this option is better for you.
Catch you later! ![]()
Best Answer01-26-2017 05:00
01-26-2017 05:00
As I said, I used it in normal mode to begin with and it said I was asleep from the minute I got into bed until the minute I got out of bed. That is not correct. I usually wake a couple of times in the night. I was hoping for some insight into those periods of being awake but I am just not getting that kind of useful data that I was hoping for.
