06-29-2016 12:11
06-29-2016 12:11
Is there a way to make the GPS data calculate things over time, as opposed to distance?
Like at x time I was going y fast, instead of at mile x I was going y fast?
08-17-2016 14:22
08-17-2016 14:22
All you do is click on the excercise in question, and while hovering your mouse over any of the graphs, you will see a clock at the bottom of the graph you're mousing over. Click that and all your graphs will be over time instead of distance!
06-29-2016 12:32
06-29-2016 12:32
Nevermind. I found out how.
08-17-2016 14:07
08-17-2016 14:07
@Akoto welcome to the forums! It's nice to read that you've found out how to make your GPS to calculate your time instead of distance. If you'd be so kind to post here how you did it so other users can learn how to do it. That's definitely going to help lots of other users wondering the same. Looking forward to your new comments!
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
08-17-2016 14:22
08-17-2016 14:22
08-17-2016 15:00
08-17-2016 15:00
@Akoto awesome! Thanks for sharing. 🙂 I'm confident this will definitely help other users. Keep up the great work!
