05-05-2018 06:25
05-05-2018 06:25
I decided to track my exercise instead of using the automated tracker for my walk. It only calculated 5k steps for my 4.2 mile walk. Impossible that it's only 5k steps! Not sure how to rectify this, I have a 10k step goal each day and I don't have time to walk another 2 miles just to reach it!
05-09-2018 11:37 - edited 05-09-2018 11:38
Hi @Angie1088 it's always great to see new people around, welcome! Thanks for the help @WendyB.
Thanks for the details you included in your post, it helps a lot! It sounds odd that your Fitbit is giving you different steps readings but let's take a look of some details first. It's important to specify whether you wear the tracker on your dominant or non-dominant wrist, please check the recommendations about choosing the correct Handedness and perform a restart on it. You can also perform a quick accuracy test for steps, so we can verify how is this working.
1. Put your Surge on your.
2. Walk 100 steps, making sure to count a step each time one of your feet hits the ground.
3. Pause, then check your tracker to see your step count.
If your tracker counted less than 100 steps or more than 100, please let us know and we'll see if we can investigate further. Sometimes, when you start walking you may notice that your steps may not update on your tracker right away. After about 10-15 continuous steps, you'll notice the steps catch up and start updating in real-time with each step you take.
Hope this helps!
05-06-2018 11:24
05-06-2018 11:24
Were you holding on to anything? As it needs to see the arms swinging
Wendy | CA | Moto G6 Android
05-06-2018 12:20 - last edited on 05-09-2018 11:13 by YojanaFitbit
I wasn't holding anything lol
Angeline S
Moderator edit: Removed personal information.
05-06-2018 12:27
05-06-2018 12:27
Have you set your stride correctly?
05-06-2018 20:01 - edited 05-06-2018 20:01
https://help.fitbit.com/articles/en_US/Help_article/How-do-I-measure-and-adjust-my-stride-length/
Please give more info on what you are Using Etc. Its hard to help with the info you give which is nothing
05-07-2018 02:31 - last edited on 05-09-2018 11:11 by YojanaFitbit
Yes
Angeline S
05-07-2018 02:58
05-07-2018 02:58
You give no information as to what you are doing so I cant help. Best of luck
05-07-2018 03:04 - last edited on 05-09-2018 11:12 by YojanaFitbit
I walked just like I normally do. Only difference was I tracked my walk
instead of letting the surge do it for me automatically. I wanted to be
able to see my pace and splits. But I did 4.16 miles and it only logged a
little over 5K steps. Yesterday I didn't track my walk, I let the Surge do
it for me and 3.4 miles gave me around 8K steps. I didn't do anything
differently while walking.
Angeline S
Hope this helps!
