10-16-2016 08:48
10-16-2016 08:48
Best Answer10-20-2016 09:04
10-20-2016 09:04
Hi there @Roxie24, good to see you around. Are your referring to your Active minutes? or your total time of the exercise?
Note that if you are referring to Active Minutes it will depend of the intensity you re doing an exercise, since it wont math the total time of the activity, in some other cases it depend of the activity itself. Also subtle differences in exertion may explain why two seemingly identical activities result in different active minute totals.
However you mentioned that on your tracker is working, so I recommend to review your Web-based Dashboard on your Activity History to see if your minutes are being counted.
If you believe the app is not working, try to Log out from the app and restart your device. Once it has loaded, log back in and try again.
Keep me posted how it goes, I'll be around.
10-20-2016 12:26
10-20-2016 12:26
