04-28-2018
02:25
08:48
04-28-2018
02:25
08:48
Hi, @GrumSup, the best way to track stand up paddle boarding would be to create a "custom activity". You need to do this in the web-based program, not in the app (go to Activity Logs and then scroll down -- on the bottom right you will see a box to create a custom activity). Once you have created the activity on the web program, it will be available to you in the app.
When you are paddle boarding, track it using "workout" mode on the Surge. Workout mode is designed so that you can rename it to any activity you like. When you have synced your workout you can use your app to rename it to SUP (or whatever name you have created for your activity)
I hope this is clear! Please post again letting us know how you usually sync your Surge (iOS, Android, Windows or computer) if you would like more specific instructions.
Welcome to the forums!
