01-16-2016 16:31
01-16-2016 16:31
01-16-2016 18:31
01-16-2016 18:31
@Maiwill07 You've probably already seen this but check out the battery maximizing tips. Basically, turn everything off that you don't really need. It's also a good idea to restart it.
Best Answer01-17-2016 00:48
01-19-2016 19:28
01-19-2016 19:28
same thing here. ....there's a long thread going. Problems started mid December is the general consensus. Turning off all day sync in the app seems to help some. They've sent me 2 replacments so far.
01-21-2016 07:51
01-21-2016 07:51
Hello @Maiwill07, @shelbean91, @SunsetRunner and @SunsetRunner! hope you are all having a great day. Thanks for your amazing cooperation @SunsetRunner and @SunsetRunner It's great to have you here
@Maiwill07 if you already tried the suggestion on the help articles: How do I maximize my tracker's battery life? and My tracker's battery isn't charging please contact customer support so they can review the battery behavior. Let me know how it goes. 🙂
Catch you later! 😉
It is health that is real wealth and not pieces of silver and gold! Share your story!
01-22-2016 08:11
01-22-2016 08:11
This is another thread with more information:
https://community.fitbit.com/t5/Surge/Battery-Life-Suddenly-48-Hours/td-p/1062214
the short version is that there's something with either the mobile app or the latest Fitbit firmware that's killing the battery.
Best Answer01-23-2016 05:50
01-23-2016 05:50
Hello @livewire98801 it's great to see you around! Thanks for sharing this information 🙂 hope to see you posting more often.
Catch you later! 🙂
Best Answer03-15-2016 05:20 - edited 03-15-2016 05:23
My surge has droped power to 1 day twice now fixed mine by uninstalling the app then reinstalling and resetting the surge, back to normal android 4.4.4 maybe a help to other users
cheers brillo
Best Answer03-17-2016 15:45 - edited 03-17-2016 15:46
Hello @brillo welcome to the Fitbit Community! It's great to have you here
Thanks for taking the time to share the troubleshoot you performed, I'm glad to know it worked!
Happy stepping! ![]()
Best Answer06-20-2016 20:03
06-20-2016 20:03
