06-15-2016 06:55
06-15-2016 06:55
I have a fitbit surge that I really like but the clasp on the band fell off. The other parts of it are there (the spring thing through the band and the other prong deal) but I could not find the clasp part. Can I order the replacement band for the Blaze and take the clasp off of it to fix my Surge?
I know the 28mm band on the Surge but what size is the Blaze band clasp?
Thanks
Ron Gerth
Best Answer06-15-2016 07:48
06-15-2016 07:48
There is no way to replace the band
I would contact support and see what they can do for you
Wendy | CA | Moto G6 Android
