I need a replacement band for my surge, I bought it in December 2015. It is worn on the front and split between the screws. Can I send it off to have a new one fitted? How much does it cost? Or can I buy a replacement band and fit it myself?
Welcome to the forums!
I'm sorry but the band is not replaceable. Or can it be repaired
Its out of warranty but you can contact support and they will give you a discount
Contact Support
http://help.fitbit.com/?cu=1
Check out the discussions boards! A lot going on and I'm sure you have some contributions as well!
Hope to see you around!
Wendy | CA | Moto G6 Android
