12-01-2016
17:28
18:29
EstuardoFitbit
12-01-2016
17:28
18:29
EstuardoFitbit
Does anyone know if you set the timer for a certain amount of time, will it go to that same timed amount the next time you use it? In other words, does the timer save the last setting? Tx, Tammy
12-02-2016 05:18
12-02-2016 05:18
A warm welcome to the Community @Tammy-R. Regarding to your question, yes, your tracker will save the timer you set for the last time. If you want a new time you can change it without an inconvenience.
Catch you later.
12-07-2016 19:25
12-07-2016 19:25
Awesome! Thanks so much.
12-12-2016 09:29
12-12-2016 09:29
Hope you’re enjoying the forums @Tammy-R! It's great to know that you find your answer here. I invite you to mark @AlejandraFitbit's post as the solution. Marking posts as solutions is a great way of thanking another community member while also highlighting their solution so that it may be discovered more easily by other community member's facing the same questions or issues as you. You can read more about Accepted Solutions here.
I'll be looking forward to your new comments!
