Welcome to the forums!
If you bought it here contact support. Or take it back to where ever you got it and exchange it.
Contact Support
http://help.fitbit.com/?cu=1
Check out the discussions boards! A lot going on and I'm sure you have some contributions as well!
Hope to see you around!
Wendy | CA | Moto G6 Android
07-19-2017
11:18
09:31
YojanaFitbit
07-19-2017
11:18
09:31
YojanaFitbit
Exactly the same as mine put on charge remove and dies in seconds. The instructions are a joke for such an expensive item IMO
Mines exactly the same .The instructions are a absolute joke .Fit bit hang your heads
07-24-2017
17:31
09:36
YojanaFitbit
07-24-2017
17:31
09:36
YojanaFitbit
Customer support is awful but they will offer to sell you a replacement at a discount. Toss it in the trash and buy a different brand with reputable Customer Service.
And customer service is a joke. They will offer to sell you a new one at a 25% discount rather than replace your current device.
Moderator edit: Word Choice
Hi @RogerMonahan, @Jase72 and @clarkfp! Nice to see that you're digging into the Forums! Thanks for the suggestion @WendyB! ![]()
@RogerMonahan and @Jase72 Sorry about what happen to your Fitbit Surge, I'd recommend restarting your it to see if this helps! If it doesn't, our team is always trying to give the best option for users using your Fitbit warranty, so in case that you haven't contact our Support Team, please let me know so I can arrange they can contact you directly!
@clarkfp Thank you for the thorough feedback for the Fitbit environment, customer service, platform and devices. This has not gone unnoticed and be sure that I will pass this along.
I'll be around!
