04-08-2017 05:26
04-08-2017 05:26
Just bought a surge and it won't go past the setup screen not even after a restart. Any other suggestions? Rather dissapointed.![]()
Best Answer04-08-2017 06:08
04-08-2017 06:08
Did you go through the setup procedure via the fitbit app ok? The setup screen is the only thing it will display until that's complete.
04-08-2017 06:08
Best Answer04-08-2017 07:05
04-08-2017 07:05
Ah Yes now up and running. Far too eager to get it going. Thank you.
Best Answer04-08-2017 07:06
04-08-2017 07:06
Ah Yes far too eager to get it going.
Thank you.
