Hey there, @Ccookeod! Welcome to the Family! Thanks a lot for your help @Seanessy! ![]()
Sorry to read about your Surge, as @Seanessy said, it's best to contact our Support Team, so they can check your information and provide you with the best solution based in your Fitbit warranty. You can reach them via email, or if you prefer you can chat or calling them at:
.Keep me posted with the outcome! ![]()
Best AnswerAlready contacted them and have received a replacement surge. Still not satisfied in how this all went down. A replacement band or a better product needs robbery developed or people will quickly go somewhere else.
03-01-2017
10:46
07:47
YojanaFitbit
03-01-2017
10:46
07:47
YojanaFitbit
So again Fitbit, when are you going to replace mine. Three Surges in 16 months and now I am stuck with a $250 piece?
Moderator edit: Word Choice
Best AnswerHappened to me. Just finished a conversation with support. The band is not replaceable, and outside the warranty, the only option is buy a new one. They offered me a 25% discount!
This is disgraceful design. It is obvious that the band will wear and break.
Best AnswerI purchased my surge in fall 2015 and my band is also breaking at the screws. Seems crazy - I don't abuse it, just normal use, it should not be breaking down in this way. Also my green pulse light has just stopped working, so no heart rate monitor now. Tried restarting, etc. Am def thinking of an Apple Watch now! This is not good.
Best Answer@NateC44 @kttaylor Replacement bands are available from AliExpress. Plenty of videos on YouTube to show you how to do it. Around 20$ USD, inluding the TORX screwdriver needed to replace it. Beats throwing a perfectly good Tracker in the bin and way cheaper than a new tracker even with FitBit's discount.
a google search found this supplier. I got one and fitted it. It does the job, arrived in about three weeks, and cost about $20.
